Connection from shallow well pump to pressure tank
Tangerineman
Ontario
Can the connection from my pump to the pressure tank be just 1 1/4" poly plumbing hose?
The old arrangement has a series of metal connectors and using poly would be easier for me. Thanks in advance!
I think you are saying you have a jet pump, so yes. Is the pressure switch on the pump, and you are talking less than 4 ft of poly? If the poly is long, the pressure switch should be at the pressure tank.
Tangerineman
Ontario
The jet pump is about 3.5' away.
The old set up has a turn off valve between the two, but I'm not sure why.
Thanks for your help.
