Connecting washing machine hose
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by noobe, Sep 21, 2012.
  1. noobe
    noobe New Member
    Sep 21, 2012
    Cairo
    Hello, so I got this new washing machine that I need to connect the hose to. Problem is, I am not sure how to connect it. The hose has 2 sides, one is L shaped 90 degrees and the other is straight. According to the manual, the L shaped side should be connected to the washing machine with 45 or 35 degrees bent.
    [​IMG]
    On my old machine, I connected the L shaped side to the water side while connecting the straight side to the machine. So, what is the right way to connect the hose. I am so confused. I do not want to break the new washer.
    Thank you for your time.
  2. Terry
    Aug 17, 2004
    Those 90 degree bends confuse me too.
    It depends on you situation. I would look at the hoses both ways and see which way looks best. It may be that the 90 bend works better at the wall shutoffs.
  4. noobe
    noobe New Member
    Sep 21, 2012
    Cairo
    Thanks for the reply, sir. Thing is, the manual is the issue here. I do not know why it insists on bending the hose left or right. Would connecting the hose anyway different than whats shown in the manual affect the washer badly or they are all the same?
    Edit: I have the washer in the kitchen, while the water source is in the bathroom. The faucet is very close to the ground, and the hose is passed through the wall in a pipe.
  5. bluebinky
    bluebinky Member
    Aug 31, 2011
    Software Engineer
    Santa Clara, CA
    Possibly to avoid a "bump" or high spot on the back of the unit? Also, the connection point may be susceptible to breakage if the hose points straight down and is pushed in or out with some force. Just guesses...
  6. noobe
    noobe New Member
    Sep 21, 2012
    Cairo
    After checking some other manuals, I decided to go with the L shaped side into the washer. Thanks again for the replies.
  7. hj
    The instructions are usually written by someone who has not even seen the machine and is using a description from an engineer. You can use the hoses either way, but the elbows on the machine usually allow it to slide back further without squeezing the hoses. The 35 degree/45 degree recommendaton is probably someone idea of being "cute". Why wouldn't 15 degrees or 25 degrees do the same thing, which is NOTHING as far as the hoses are concerned? Directions like that must be why we do NOT read the installation manuals.
  8. bluebinky
    bluebinky Member
    Aug 31, 2011
    Software Engineer
    Santa Clara, CA
    I agree with you hj. However, there was probably a problem uncovered during testing. As an engineer, I can say that the steps involved in getting to the final manual are often way more complicated than you'd think they should be. The 35/45 degree numbers are probably the result of extended debates, what is referred to as "politics", and possibly some stupid lawyer to satisfy.
    In the end, just be careful when you move the machine around as the connection point is probably a bit weak.
Similar Threads: Connecting washing
Plumbing Forum, Professional & DIY Advice Please help connecting washing machine water pipe Mar 8, 2011
Plumbing Forum, Professional & DIY Advice Connecting L copper to M copper Mar 11, 2017
Plumbing Forum, Professional & DIY Advice Connecting new shower drain to existing tub drain Mar 5, 2017
Plumbing Forum, Professional & DIY Advice Connecting additional shower drain to an existing tub drain. Feb 28, 2017
Plumbing Forum, Professional & DIY Advice Weird thing with flushomatic toilet; tube connecting pipe to wall Aug 30, 2016
