connecting trap to galvanized nipples
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by bbillcee, Feb 23, 2011.
  1. bbillcee
    bbillcee Member
    Feb 25, 2007
    New York
    can u use a pvc trap and slip nut just like u would a brass tubular when connecting to a galvanized nipple?
    over the years i always find the gal rots where connecting to the brass
  2. Tom Sawyer
    Tom Sawyer In the Trades
    Nov 29, 2010
    Maine
    If the nipple is in good shape, yes. Screw a female adapter on and go from there.
  4. jadnashua
    Not all that looks like brass is solid brass! A solid brass piece should last when connected to galvanized, but a plated piece would quickly start to corrode. Also, keep in mind that the threaded portion of the galvanized doesn't likely have any galvanized metal on it, or if it did, it was damaged. So, bare steel will corrode more easily.
  5. hj
    The way you ask it, NO! You screw a Marvel connector/trap adapter/DeSanko, (whatever they call it in your area), onto the pipe and then use ITS slip nut and washer to secure the trap. You do NOT install the slip nut directly onto the pipe.
    [​IMG]
  6. ilya
    ilya In the Trades
    Dec 10, 2009
    home repair -I am not licensed and never represent
    Akron Ohio
    hj-Are there trap adaptors with female threads? I've always had to glue 'em up.
  7. bbillcee
    bbillcee Member
    Feb 25, 2007
    New York
    thanx hj, one of the nipples is 2" what is the best way to bring down to 1.5 inch? just a reducer coupling with a 1.5 nipple then the desanko? also can the desanko be used to transition to a PVC trap or just brass or both?
  8. Tom Sawyer
    Nov 29, 2010
    Maine
    If you have the room yes a reducing coupling is going to be the easiest thing to find.
  9. hj
    with the 2" nipple you could not connect the trap directly to it anyway. Yes, there are brass trap adapters with male or female threads. A 2 x 1 1/2 reducing coupling and a male trap adapter will give you the shortest connection. And the brass adapters are for use with ANY trap material, although you would normally replace the brass ring with a nylon slip joint washer.
Similar Threads: connecting trap
Plumbing Forum, Professional & DIY Advice drain help connecting p-trap Sep 30, 2013
Plumbing Forum, Professional & DIY Advice Connecting two traps together to maintain prime Sep 4, 2013
Plumbing Forum, Professional & DIY Advice Bathroom sink: Connecting plastic pop-up to metal trap Nov 8, 2011
Plumbing Forum, Professional & DIY Advice Connecting plastic sink drain to metal p trap Oct 5, 2010
Plumbing Forum, Professional & DIY Advice Connecting P-trap to drain for tub May 8, 2010
