Connecting to Cast Iron P-Trap
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by gransom, Jul 5, 2009.
  1. gransom
    gransom New Member
    Jul 5, 2009
    Texas
    I am replacing a tub, a picture of the P-trap is below. A 1.5" pvc pipe was inserted into the hole. What is the correct way to fit the waste and overflow pipe into this existing hub? There is not enough pipe coming out of the hub to attach an adapter.
  2. nhmaster
    nhmaster Master Plumber
    Jul 30, 2008
    Tech. Instructor
    S. Maine
    You need one of these.
  4. hj
    drain
    The correct way is to remove the lead, remove the pipe stub, insert a new pipe stub of the proper length, and then repour the lead joint. Assuming it is in the proper location for the new fixture.
Similar Threads: Connecting Cast
Plumbing Forum, Professional & DIY Advice Connecting PVC to Cast Iron. Fernco likely will not fit... :( Jan 6, 2015
Plumbing Forum, Professional & DIY Advice Connecting PVC section to damaged Vertical Cast Iron of Different Diameter Sep 7, 2013
Plumbing Forum, Professional & DIY Advice Connecting PVC bathroom sink drain to old cast iron drain T Jan 12, 2013
Plumbing Forum, Professional & DIY Advice Connecting New PVC Pipe Vent to Existing Cast Iron Vent Pipe in a Wall for Toilet Oct 11, 2012
Plumbing Forum, Professional & DIY Advice Connecting 4" Cast Iron with 3" PVC Sep 17, 2012
