Connecting the dimmer switch to the nuetral line?
Discussion in 'Electrical Forum discussion & Blog' started by Erico, Apr 14, 2009.
  1. Erico
    Erico Member
    Nov 17, 2007
    Chicago, IL
    M
  2. Speedy Petey
    Speedy Petey Licensed Electrical Contractor
    Jun 16, 2007
    NY State, USA
    Well, for one it is a serious code violation and has been for MANY years.
    Having the hot side hot all the time is only half the issue. With the neutral switched the neutral is also hot as it is being backfed through the load to the switch. So anyone working on the circuit (like him I bet) without shutting it off completely could be in for a (possibly deadly) surprise.
    If he is this insistent on doing something so stupid and wrong I would be suspect what other violations he is adamant about creating. :rolleyes:
  4. Thatguy
    Thatguy Homeowner
    Aug 27, 2008
    A bounty hunter like in "Raising Arizona"
    MD
    As to functioning it should make no difference. The dimmer, source and load won't "know" it.
  5. killavolt
    killavolt In the Trades
    Apr 9, 2009
    Licenced electrician
    Southington CT
    If you have a black and a white wire (only) coming into the box the switch was mounted in you have a switch leg coming in. The white wire should have been identified as such and marked accordingly.
  6. Speedy Petey
    Jun 16, 2007
    NY State, USA
    Killa, from the sound of the OP it seems this old guy really is switching the neutrals.
  7. Erico
    Erico Member
    Nov 17, 2007
    Chicago, IL
    yes
    You are correct
Similar Threads: Connecting dimmer
Electrical Forum discussion & Blog Connecting surge suppressor to spa GFI breaker. Aug 17, 2016
Electrical Forum discussion & Blog Connecting Outside Generator to Transfer Switch Nov 6, 2011
Electrical Forum discussion & Blog Connecting Neutral and Ground at Power Outlets Oct 31, 2010
Electrical Forum discussion & Blog 2 Properties Connecting to Submersible Well Pump Oct 30, 2010
Electrical Forum discussion & Blog Double oven and cooktop wiring - connecting three #6 wires Sep 18, 2010
