NSB00
I plan to run a new drain pipe for a main floor half-bath lav down into the basement space. From the basement side I will connect to the end of an existing branch.
In the attached photo, the branch joins the main stack about 6 ft to the left. The branch connects to an existing drain pipe that drops down from a wall over the rim joist. The branch terminates with a cleanout that has only about 12 inches of clearance.
The new half-bath lav drain will drop through the floor about 1 ft to the right of the branch(dropping between the 2 joists spaced 6" apart).
The new pipe and fittings will be 1-1/2" PVC and will be joined to the old galvanized pipe with shielded couplings.
I hope the attached drawing makes sense. The drawing is supposed to show how I think I can assemble this to accommodate both the old and new drains and the cleanout. The new horizontal section will be about 3 inches below the bottom of the joists.
Snaking through the new cleanout will require going around that new 90 degree bend. But now there will be more than 18" of clearance behind the new cleanout.
If there is a better way to do this, I will be happy to change my plan. I sketched up some other ways to do this but they were more complex and required more fittings.
