Connecting metal drain to copper waste pipe
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by jlongo08889, Dec 27, 2006.
  1. jlongo08889
    jlongo08889 New Member
    Dec 27, 2006
    Hi .. I am pretty new to do it yourself plumbing. I am re-doing a half bath & when removing the sink, the metal drain pipe was so corroded, it broke a few inches beyond the copper waste pipe. How do I get the rest of the metal drain out & subsequently, how do I re-attached the new metal drain to the copper waste pipe? Looks like it is just soldered in?? Does that sound correct?
  2. Randyj
    Randyj Master Plumber
    Nov 25, 2006
    Alabama
    Got any pictures?
  4. Mike Swearingen
    Mike Swearingen New Member
    Jan 12, 2005
    Independent Real Estate Broker
    On Albemarle Sound In Northeastern NC
    Pictures will help.
    If it is straight piece of 1.25" chromed drain pipe, you can hacksaw off the corroded section and connect it to a similar piece of pipe from the trap with a rubber coupling with stainless steel hose clamps made for the purpose and acceptable to code (aka Fernco brand name coupling).
    OR saw it off and use a compression slip joint connection on it.
    Mike
  5. hj
    Fernco
    The Fernco with a rubber sleeve and two clamps is not accepted by codes. It is also a poor way to make the repair. The proper way is to cut the piece out of the drain and then put a new trap onto it. How to do it would require a picture so we know exactly what he is working with.
  6. jlongo08889
    Dec 27, 2006
    thanks for replys
    Thanks for the replys ... I will try to get a picture out here ... basically just a 3 - 4 "" peice of chrome pipe straight sticking out of the copper pipe. The chrome pipe ends just where the curve downward begins to start the P trap. The ens are a jagged mess because of how it snapped.
    thanks -- Jlongo08889
  7. Randyj
    Nov 25, 2006
    Alabama
    Hmmm... trap adapter with appropriate nut & washer (male adapter with nut for 1 1/4" drain pipe)... cut tail piece and add tail piece extension with its appropriate nut and washer. To get the old piece out use something like a punch, chisel, etc. to drive in between the tube & pipe and try to get a bite on it with pliers or vice grips to pull it out... may have to heat pipe with propane torch.
Similar Threads: Connecting metal
Plumbing Forum, Professional & DIY Advice Connecting Vanity drain to Unthreaded metallic drain pipe sticking out of the wall... Sep 15, 2013
Plumbing Forum, Professional & DIY Advice Gas line-connecting different metals - Need guidance Jul 30, 2012
Plumbing Forum, Professional & DIY Advice Bathroom sink: Connecting plastic pop-up to metal trap Nov 8, 2011
Plumbing Forum, Professional & DIY Advice Connecting plastic sink drain to metal p trap Oct 5, 2010
Plumbing Forum, Professional & DIY Advice Connecting L copper to M copper Mar 11, 2017
