connecting drain to lead pipe
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by new to plumbing, Dec 6, 2008.
  1. new to plumbing
    new to plumbing New Member
    Dec 5, 2008
    Hello,
    The other day I decided to replace the old vanity in my bathroom. However I have run into an issue. The house is a 80 year old house. The old metal drain is soldered to a lead pipe. Photos are attached. I am not sure what the best way would be to connect the new drain. The pipe OD of the metal drain pipe is 1 1/4". It appears that the lead pipe OD is slightly larger. Any suggestions on how to approach will be much appreciated.
    Thanks
    Tom
  2. hj
    drain
    The safest and easiest way is to call an old plumber who knows how to solder the new trap to the lead.
  4. gardner
    gardner DIY Senior Member
    Apr 2, 2007
    Ontario
    a possible idea from someone who knows no better
    If the chrome pipe is sound, you can cut the bend off leaving a nice straight length. Then a slip fit 1-1/4 pipe length will fit over that and reach to your trap. Look for a chrome pipe with a nut and polyethylene washer at one end at your local plumbing mart.
    Many around here would pooh-pooh that bottle trap in your photo. Do you need to use that trap? Because if you could go with a standard trap, there may be no need to muck with the trap arm at all.
  5. Master Plumber Mark
    Master Plumber Mark Master Plumber
    Feb 6, 2005
    Sensitivity trainer...healey-feeley.....
    the easy way to do it....
    HJ,
    you would never catch me soldering that lead joint
    back together...aint no way.......
    all you got to do is get a hack saw.
    .or sawzall with a steel cutting blade.
    and cut that lead off right behind that lip...
    you might have to open up the drywall a little bit...
    but it looks like you got plenty of room
    then all you have to do is go get a 1 1/4 grey fernco coupling..
    grease the lead up with some pipe dope...
    then slide the fernco fitting half way onto the pipe and clamp it down tight..
    then simply put the arm of your new pvc trap into the
    other end of the fernco...with some pipe dope on it and.
    clamp it down...
    very simple , very easy....
  6. new to plumbing
    Dec 5, 2008
    Thank you!
    Thanks all for your input. It's time to make a decision - most likely will call a plumber for the job
Similar Threads: connecting drain
Plumbing Forum, Professional & DIY Advice Advice connecting additional shower to existing horizontal drain Mar 24, 2016
Plumbing Forum, Professional & DIY Advice Connecting Shower drain to the toilet drain Mar 6, 2016
Plumbing Forum, Professional & DIY Advice Connecting shower drain to a pitched toilet drain, help! Dec 12, 2015
Plumbing Forum, Professional & DIY Advice Connecting new lav drain to existing branch, relocating cleanout Oct 12, 2015
Plumbing Forum, Professional & DIY Advice Connecting 1-1/2" to 1-1/4" drain pipe Mar 21, 2015
