Connecting “Flex Duct†to a heater
Discussion in 'HVAC Heating & Cooling' started by lahabra, Mar 12, 2008.
  1. lahabra
    lahabra New Member
    Dec 21, 2007
    California
    I am planning a new heater install, I want to use Flex-Duct for the supply air and for the Return air.
    I am concerned that the hot air could melt or burn the plastic hose if it is too close to the burner.
    1. Can I connect Flex Duct directly to the a heater?
  2. jadnashua
    I don't think so. There are some metal flexible ducts, but rigid ones probably work better. I do not know what the codes say. The additional turbulance and friction will slow the air down, too, and give any dust a good hiding place to build up.
  4. Nubbin
    Nubbin New Member
    Mar 30, 2008
    duct
    some codes/install instructions require the flex duct to be kept 4 inches away from ANYTHING that reaches 250 degrees F. The outlet of a gas furnace is often limited to 160-180. However, a short plenmum will move the duct(s) further away from the radiant heat of a heater and improve air flow and reduce a chance of causeing hot spots in your heater that would void your warrant.
Similar Threads: Connecting “Flex
HVAC Heating & Cooling Connecting a new radiant heat zone for a garage slab to an existing baseboard boiler heating system Nov 12, 2014
HVAC Heating & Cooling Connecting the "Fan "Only" on Thermostat Dec 11, 2013
HVAC Heating & Cooling Connecting air duct to air register Oct 8, 2013
HVAC Heating & Cooling Using a HVAC Condensate Pump or Directly Connecting to Sewer Line w/trap Jun 26, 2012
HVAC Heating & Cooling Connecting a HRV to a furnace Jan 24, 2011
