Connecting a 1-1/4" fleck 7000 bypass valve to water supply
Discussion in 'Water Softener Forum, Questions and Answers' started by geod, Feb 23, 2011.
  1. geod
    geod New Member
    Feb 23, 2011
    Ottawa, Ontario
    Connecting a 1-1/4" fleck 7000 bypass valve to 3/4" water supply
    Hi,
    I just got a new water softener in to replace our old sears kenmore water softener. It's has a Fleck 7000 control valve with a 1-1/4" plastic bypass valve. The new water softener bypass valve came with two plastic 1-1/4" male threaded plastic fittings to connect to the water supply.
    My problem is that currently the kenmore is connected with two corrugated copper hoses that are 3/4" on the water supply side and 1" on the water softener side. I've looked in home depot, but couldn't find anything to connect my 3/4" water supply to the new water softener's 1-1/4" threaded connections.
    Any suggestions on where I can find a connector.
    Thanks,
    geod
  2. mialynette2003
    mialynette2003 Member
    Nov 24, 2010
    Owner of SWS Systems WWW.SWSSYSTEM.COM
    Ocala, Florida
    Are the copper hoses threaded on both ends? If so, you can convert to pvc simply by attaching a pvc female adaptor on the incoming line then bushing up to 1 1/4" and attach a female adaptor to the bypass valve. Do the same on the soft water side.
  4. Akpsdvan
    Akpsdvan In the Trades
    Dec 29, 2009
    Business owner/service and sales
    Alaska
    Look for a plumbing supply house for the part that you are looking for.
    You might find the 1 1/4 to 3/4 in one part or you might have to step it down in 2 or 3 parts per side..
  5. geod
    geod New Member
    Feb 23, 2011
    Ottawa, Ontario
    Thanks for the replies. I visited the local plumbing supply house and got a 1 1/4 to 1" corrugated stainless steel hose along with a 1" to 3/4" bushing. I've got the softener hooked up and its working great.
Similar Threads: Connecting 1-1/4
Water Softener Forum, Questions and Answers Connecting softener to copper Dec 11, 2014
Water Softener Forum, Questions and Answers Question regarding connecting a softener May 10, 2013
Water Softener Forum, Questions and Answers 1-1/4" PEX, is a DIY install possible? Mar 22, 2010
