Connecting #6 conductors
Discussion in 'Electrical Forum discussion & Blog' started by Smith333, May 9, 2010.
  1. Smith333
    Smith333 Member
    Sep 5, 2006
    Wisconsin
    I need to connect (2) #6 conductors, but the largest wire nut I can find will only handle (1) #6 with (1) #8. Does such a wirenut exist or do I have to use something else? TIA
  2. Lightwave
    Lightwave New Member
    Aug 20, 2007
    Vancouver, BC
    There are wirenuts for #6 wire. Keep looking.
    edit: Ideal part 30-454 is what you want.
  4. hj
    For the load you must have, I would prefer "Bundy lugs" or similar which clamp the wires together, and then tape over them.
  5. Smith333
    Smith333 Member
    Sep 5, 2006
    Wisconsin
    Thanks for the info, I had to try a different store and they had the correct wire nuts. It's for a hot tub neutral in a service disconnect box (GFCI breaker is in main panel).
Similar Threads: Connecting conductors
Electrical Forum discussion & Blog Connecting surge suppressor to spa GFI breaker. Aug 17, 2016
Electrical Forum discussion & Blog Connecting Outside Generator to Transfer Switch Nov 6, 2011
Electrical Forum discussion & Blog Connecting Neutral and Ground at Power Outlets Oct 31, 2010
Electrical Forum discussion & Blog 2 Properties Connecting to Submersible Well Pump Oct 30, 2010
Electrical Forum discussion & Blog Double oven and cooktop wiring - connecting three #6 wires Sep 18, 2010
