Connect to main
Discussion in 'Irrigation / Sprinkler Forum' started by Hammer8789, Dec 13, 2012.
  1. Hammer8789
    Hammer8789 New Member
    Dec 13, 2012
    McHenry, Il.
    We are having an irrigation system installed. The plumber is here connecting to our main line. What he has done is nothing like I have ever seen, though he says it will be fine. We are on a well so my main runs in with a 1" pvc flex to the baffle/pressure tank. comes out with 1" galv. pipe and reduces to a 3/4' valve then feeds the house. He has cut the 3/4' line after the valve and installed a 3/4 x 3/4 x 1" T. The 1" is what he is running to feed the irrigation system. I would have removed the reducer, replaced the 3/4" valve with a 1" then installed a 1"x 3/4"x 1" T and moved on. It just doesn't seem right to feed a 1" pipe with a 3/4 ". Who is right?
  2. Terry
    Aug 17, 2004
    A small section of 3/4" isn't going to have much effect.
    With city water, the setters are 5/8" or 3/4", and we run 1" or 1-1/4" off of those.
    A long distance of 3/4" would have been more of a worry, the distance adding to the friction loss.
    If you look at a hosebib, the port that the water comes through is very small. And yet it will gush out of there.
Similar Threads: Connect main
Irrigation / Sprinkler Forum Drip Irrigation system often leaks at barb connections to mainline Jun 22, 2016
Irrigation / Sprinkler Forum Connecting irrigation to water main with pex homerun system Apr 11, 2012
Irrigation / Sprinkler Forum Is it against code to connect a timer to a hose bib? Feb 18, 2017
Irrigation / Sprinkler Forum Which part do I need to connect new pipe to existing pipe? Jan 29, 2017
Irrigation / Sprinkler Forum Possible top connect 2 valves in one zone? Jun 22, 2014
