Connect septic pipe to septic tank????
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Blueboat, Oct 27, 2012.
  1. Blueboat
    Blueboat New Member
    May 3, 2012
    Arizona
    I am running 3 inch ABS from the house to the septic tank, there is about a 4 to 5 inch hole in the cement lid of the septic tank. What goes between the tank and the 3 inch pipe to connect the two? Is there some kind of fitting?
    Thanks for your help.
    Mike
  2. hj
    Your pipe goes into an opening on the "end" of the tank, NOT into the lid. There should either be a hole for you to stick the pipe into, or a piece of pipe for you to connect to. Openings on the top of septic tanks are for cleanout purposes ONLY.
  4. Blueboat
    Blueboat New Member
    May 3, 2012
    Arizona
    Thank you hj.
    Mike
Similar Threads: Connect septic
Plumbing Forum, Professional & DIY Advice Footing Drains Connected to Septic? Dec 29, 2013
Plumbing Forum, Professional & DIY Advice Septic Connection for Half Bath in new outbuilding Sep 8, 2011
Plumbing Forum, Professional & DIY Advice ABS to PVC Septic Connections May 3, 2011
Plumbing Forum, Professional & DIY Advice Septic connection Aug 9, 2007
Plumbing Forum, Professional & DIY Advice NPS (Straight Thread) Fitting OK for Hidden Connections? Apr 5, 2016
