idloveaguinness
- Messages
- 4
- Reaction score
- 0
- Points
- 0
OK - here's the setup. Pro's got me all the way to 5/8" plywood with a lead pipe (3"?) sticking out of a 4" (or so) hole in the plywood that I need to connect to a flange. I've got about 16" of the lead pipe to work with. So, I guess I am putting the wonderboard and tile down, staying (how?) close to the toilet drain pipe, leaving notches for the flange bolts.
How (and at what point) do I connect the lead pipe to the flange? Is there an epoxy or a compression fitting or something else? Is there a special flange I should use?
Regards,
Kevin
Regards,
Kevin
