Connect drain to air handler
Jean Vallee
Virginia
The connection where the threaded pvc fitting screws into my air handler was leaking. Replaced it and it still leaks even with generous amount of thread sealant.
What else can I try?y
How about a picture of what those PVC threads screw into. I suspect that fitting is where the leak is more likely.
Jean Vallee
Virginia
This is the fitting on the air handler. I think it has always leaked... 4 yrs old. It was a show leak onto garage floor so I never tore up that area to look for it.
Dana
In the trades
Clean the metal threads up really well with a steel bristled brush, and use a ton of teflon tape rather than goop as the sealant, see if it works any better.
I am wondering if the leak is not at the threads, but could it be around the outside of the metal thread piece?
