connect cpvc to metal shut off valve
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Gwynnefar, Apr 2, 2005.
  1. Gwynnefar
    Gwynnefar New Member
    Apr 2, 2005
    My water supply to my sink is cpvc pipe. I am replacing the old angle stop with a new metal one. I used teflon tape but it is still leaking. Any idea's.
    Thanks for any help
  2. jadnashua
    Use another layer or so of tape, or, also use some pipe dope rated for that material? I'm not a pro, but the guys that did some work for me (theydid the rough, I finished it), used both.
  4. RioHyde
    RioHyde Plumber
    Sep 24, 2004
    Cincinnati, Ohio
    You may have tightened it too tightly or not tight enough. When transitioning from CPVC to any sort of metal I use a male adapter that glues onto the CPVC and has brass male threads. Try removing the angle stop, retaping the male threads and add some pipe dope in addition to the teflon tape. After all that is done, remove the aerator from the spout and run water to flush out the lines.
    Good luck
Similar Threads: connect cpvc
Plumbing Forum, Professional & DIY Advice Simple way to connect pressure gauge to CPVC Sep 15, 2016
Plumbing Forum, Professional & DIY Advice CPVC to brass connector leak, correct connection? Mar 4, 2016
Plumbing Forum, Professional & DIY Advice Water heater connections to existing CPVC water lines Jan 27, 2014
Plumbing Forum, Professional & DIY Advice Connecting CPVC to PVC May 24, 2010
Plumbing Forum, Professional & DIY Advice Connecting CPVC, Cooper, PEX and PBE Oct 4, 2008
