Confused - Zone Heats up but no pressure reading on external pressure gauge & no flow
Discussion in 'Boiler Forum' started by meathead, Nov 2, 2013.
  1. meathead
    meathead New Member
    Nov 2, 2013
    MN
    I have a two zone hydronic heating system. I changed out the pump and and purged the lines. On the 1st zone I purged the zone and pressurized they line to 15 psi. On the 2nd zone (upstairs), I opened the drain valve and no water came out. I added water until about 20psi and stopped. I turned on the heat anyway and had the 2nd zone call for heat. All the radiators were heating but when I opened the drain valve water was emptying. After a few days the psi on the boiler dropped to zero again. I can't find any leaks.
    Why is there heat in the pipes but I can't detect any pressure using an external gauge or purge the line?
    When the boiler pressure drops to zero could my boiler have a crack? IMG_2422_2.JPG IMG_2423_2.JPG IMG_2424_2.jpg
Similar Threads: Confused Zone
Boiler Forum Installing a combi system in an old house - confused Oct 17, 2014
Boiler Forum Adding a Zone to a Boiler Jan 9, 2017
Boiler Forum hydronic question on wiring a zone valve to shut off qravity feed to upstairs loop Jan 7, 2017
Boiler Forum How to test zone valves Feb 17, 2016
Boiler Forum Radiant floor heat zones very puzzling...any ideas? Feb 3, 2016
