CONFUSED! - Bathtub Overflow Installation - Does anyone know what this is?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by cjhusky, Dec 2, 2011.
  1. cjhusky
    cjhusky New Member
    Dec 2, 2011
    Seattle
    I am in the process of installing trim kits in my bathtub/shower combinations. But I'm severely struggling with the type of overflow assembly my plumber left me with as part of his rough-in. He has since left the area and is unreachable, so I'm reaching out to this forum, which has been incredibly helpful in the past to see if someone can help direct me.
    I am familiar with two types of bathtub overflow assemblies, either center screw or two screws. In this instance, when I unscrew the test cap, I am left with a black ABS threaded connection at the tub (see photos below).
    I must be missing something? It does not appear that this has anyway to attach your standard nickel/chrome/brass overflow trim piece. Is there some sort of aftermarket screw on assembly, which will allow me to mount a standard overflow plate and cover this up? Scratching my head here....
    The only information I have is on the test cap itself, which is marked "AB&A".
    Thanks in advance,
    chris
  2. jimbo
    jimbo Plumber
    San Diego, CA
    Cable drain, American Brass and Aluminum. http://www.abainc.net/
    click on 'catalog' then go to bath waste and trim section, pages 21-30
  4. cjhusky
    cjhusky New Member
    Dec 2, 2011
    Seattle
    Thanks for the quick reply Jimbo!
    I went to their site and looked at the cable-driven trim kits, but I'm still a bit confused. Is the cable already run as part of the rough-in, because it is certainly not visible nor can i feel it reaching in the overflow drain pipe. When I look at page 27, at say model 770, which is trim kit only, there is no cable. Is there any illustrations or instructions on how these buggers mount?
    Thanks in advance,
    Chris
  5. hj
    If it is a cable drain, the cable HAS to be installed when the waste and overflow is assembled. It is NOT an "after the fact install with the trim" item. But, if it is there should be an operating mechanism visible which operates the cable. But what you probably need is one of the Classic trim kits with the "Classic overflow plate" which comes with either a coarse pipe thread or a fine thread, depending on which you have.
  6. cjhusky
    cjhusky New Member
    Dec 2, 2011
    Seattle
    Thank HJ. That's exactly what I thought, in reference to the cable. There is certainly no cable visible, so I assume it must just be a classic drain overflow.
    I believe they are coarse thread, as shown in the pic below. Looking at page 29 (screenshot below) of the ABA catalog, there are "classic" drain trim kits for fine thread and then pipe size. Is it safe to assume that "pipe size" is for coarse thread and that mine is coarse?
    So the hope is that this will completely cover the black ABS portion INSIDE the tub and will screw down flush with the inside surface of the tub, is that correct?
    Do folks order directly from ABA or is there a recommended outsourcer? Out here in the PacNW, I order through Pacific Plumbing and sometimes Ferguson. But an online order houise may be preferable for a smal item like this, if you have a suggestion.
    Thanks again...you guys rock!!
    -Chris
  7. Chad Schloss
    Chad Schloss Member
    Jun 18, 2010
    USA
  8. cjhusky
    cjhusky New Member
    Dec 2, 2011
    Seattle
    Thanks for looking. I searched the Watco site and it does not appear to be anything like what I have. I suspect it is AB&A, due to the test cap that came off. On hj's suggestion above, I went ahead and ordered a "classic' trim kit and i'll just have to see if it fits. It looks like the overflow trim is PLASTIC, though? I had assumed it threaded onto the overflow, but maybe not? Frankly, I'm still fully confused...:(
    -Chris
  9. jimbo
    jimbo Plumber
    San Diego, CA
    The coarse and fine thread references are to the drain flange which screw down into the tub shoe. The fitting at the overflow are all the same for that series.
  10. PietjePuk
    PietjePuk New Member
    Sep 23, 2015
    Kerrville, Texas
    I have the same problem. The overflow for the bathtub only had a temporary cover installed (finishing the bathroom myself). If I look at the Watco and AB&B overflow covers they are threads only. As you can see in the picture mine has an O-ring and is not just threads. I have no idea what brand this could be. I purchased a Watco (901-LT-PVC-CP) and if I tighten the ring (item 13 from exploded view posted above) the actual cover doesn't fit (Item 14). I could cut off the O-ring and shorten it but I hate to modify it. Does anybody have any idea what the correct cover for this could be ?
    edit: finally figured it out. the manufacturer is Keeney. https://www.keeneymfg.com/featured_products/66-Seal-sup-2-sup-Test-Bath-Tub-Drain-Rough-In-Kit
    [​IMG]
Similar Threads: CONFUSED Bathtub
Plumbing Forum, Professional & DIY Advice Blue stains in the bathtub... confused as to why. Jun 11, 2011
Plumbing Forum, Professional & DIY Advice Ready to install new bathtub - confused on a couple items. Apr 17, 2010
Plumbing Forum, Professional & DIY Advice Whole House Water Filter HELP...super confused Dec 28, 2016
Plumbing Forum, Professional & DIY Advice Confused about (old style?) Moen hydrolock leak under kitchen sink Jan 25, 2016
Plumbing Forum, Professional & DIY Advice confused, need possible reasons Aug 19, 2015
