ugabulldog
I just bought some acreage and am building a house. The land had belonged to our current neighbor so I know the history. There is a 6" drilled well already on property. It has been capped and we recently had a new pump, pipe, wire installed, with pump at 240'. I had the water tested, basic and bacteria, by county/university and it came back positive for coliform and e-coli. I was told to shock water and re-test. I am new at all this, and did not test my last well after it was first drilled. After researching it seems like shocking can damage, well, parts, and address the symptom, not the cause, bacteria can re-occur... Also, e-coli is pretty common and usually not harmful? (for instance, many say chlorine in city water is bad) Should I even worry about shocking, or just use as is? One other thing I should mention is this land had chicken houses, and bury pits on it many years ago and has also been a pasture for horses, and had chicken manure spread on it.......any help or advice is appreciated as I am confused
