erk1313
Just purchased a 1950s home in NH and looking to replace the basement washer. Before I start, wanted to confirm the existing venting is acceptable.
I have left out the plumbing for the washer and utility sink for later (right now it is being piped up without a standpipe or P-trap). I can add details like diameter, lengths, types of fixture if needed, but wanted to answer some basic venting questions first to see if I need to dive into this.
1) First off, I am confused whether only the top fixture (toilet) can be stack vented, or if the entire bathroom group can be treated as a wet vent since it's off a large horizontal drain (likely not filled completely and able to pass gas). The kitchen sink2 cannot be wet-vented as part of the bathroom group, correct?
2) Does the toilet need to be downstream of all other fixtures on that branch draining to the main vent?
3) Do the S-traps violate the ability to stack vent the sinks?
Diagram of 1st floor fixtures draining below to the basement.
Thanks in advance. If this is not properly vented, then I can come up with some ideas for others to critique, along with my plan for plumbing the washer, sink, and pump.
