Conduit for Ethernet
Discussion in 'Electrical Forum discussion & Blog' started by seaneys, Dec 30, 2007.
  1. seaneys
    seaneys New Member
    May 8, 2007
    Chicago Suburbs
    Hello,
    I'm curious what everyones thoughts are for conduit for use with ethernet / video branches?
    I've seen the blue flexible conduit used on our area. Doe sit work well?
    Thanks,
    Steve
  2. jwelectric
    jwelectric Electrical Contractor/Instructor
    Jun 14, 2007
    Instructor
    North Carolina
    Depends on the application of the raceway, around my area the cable is installed without the use of a raceway in over 90% of installations.
  4. Furd
    Furd Engineer
    Jul 3, 2007
    Retired energy systems engineer
    Wet side of Washington State
    I am currently doing Ethernet, telephone and television cabling in my house and I am using a combination of rigid PVC and flexible conduit.
    I am using the rigid for main runs to and between junction & pull boxes and then the flexible to the individual branch access points.
    It makes for a VERY neat system and because most of it runs in my crawl space it also protects the wiring from rodent damage.
  5. construct30
    construct30 New Member
    Jun 16, 2007
    NorthWest PA
    I like the PVC. The blue works, but can be harder to get wire through later if they change the technology.
  6. Bill Arden
    Bill Arden Computer Programmer
    Sep 30, 2006
    computer programmer
    MN, USA
    I didn't use conduit when I ran Ethernet, telephone and television cables and everything worked well.
    One note: Don't use metal conduit with Ethernet or telephone cables since they are sensitive to nearby metal. They do make conduit ready wire, but it's better to just use plastic conduit.
  7. seaneys
    seaneys New Member
    May 8, 2007
    Chicago Suburbs
    Did you use the Flexible blue conduit?
    Steve
  8. seaneys
    seaneys New Member
    May 8, 2007
    Chicago Suburbs
    I may need to pull wires after they insulate.. It is getting cold here..
  9. portiz
    portiz New Member
    Jan 4, 2008
    I use flexible blue pipe. Works fine with me.
  10. interalian
    interalian New Member
    Dec 24, 2007
    Sr. Project Manager
    Calgary, Alberta
    Really. My office building runs 100/1G ethernet throughout, all inside metal conduit with about 60 home runs to the switch room. The conduit originally housed 25 pair telecom wire for the old Nortel SL-1, then was re-wired for arcnet (coaxial cable) and digital phones. The arcnet cables were replaced with Ethernet in the same conduits. Never a problem in 17 years.
Similar Threads: Conduit Ethernet
Electrical Forum discussion & Blog Conduit Underground from House to Garage (+water) Sep 29, 2016
Electrical Forum discussion & Blog Conduit Entering Elevated Steel SIP Home Aug 24, 2016
Electrical Forum discussion & Blog Cat5/Coax run short distance along side electric conduit Jul 18, 2016
Electrical Forum discussion & Blog NM buried in plastic conduit Jun 28, 2016
Electrical Forum discussion & Blog How many #6 wires in 3/4 inch rigid conduit? Jun 8, 2016
