Condenser fan will not run when set to heat.
Discussion in 'HVAC Heating & Cooling' started by cchrrice, May 5, 2011.
  1. cchrrice
    cchrrice New Member
    May 5, 2011
    Grant, Alabama
    My condenser fan recently stopped running, while the fan inside ran constantly with very little heat or none. I replaced the condenser fan and capacitor. The first time I turned it on it seemed to work fine. The next day is was not running again. I switched the unit to cool and it works perfectly. Switch it back to heat and you get the same thing. Nothing going on outside on the unit, but the inside fan runs all the time if you do not turn it off. What is most likely the problem?
  2. cacher_chick
    Jan 5, 2008
    Test, Don't Guess!
    In my experience, the condenser fan will only run when the thermostat is calling for heat (not cooling).
    Have you read the trouble code off the LED on the main control board?
    There is often a chart explaining the codes posted on the inside of the front panel.
  4. DonL
    DonL Jack of all trades Master of one
    Mar 30, 2011
    Rocket Scientist
    Houston, TX
    Depends if it is a heat pump.
    DonL
  5. jimbo
    jimbo Plumber
    San Diego, CA
    Are we talking a heat pump, or electric heat? Does your heating system work correctly and you are just wondering about the fan? Or is the heat not working?
  6. cchrrice
    cchrrice New Member
    May 5, 2011
    Grant, Alabama
    It is a heat pump.
    The heat is not working. The blower motor inside runs constantly with no heat. I do get heat when it is set on emergency heat.
  7. DonL
    Mar 30, 2011
    Rocket Scientist
    Houston, TX
    What is the make and model of your heat pump system ?
    That would help you to get better answers.
    I would check the time delayed change over Relay, And make sure your control programming is correct, for that unit.
    DonL
Similar Threads: Condenser heat
HVAC Heating & Cooling Mini Splits, Single vs Multi Zone Condensers Sanity Check Jul 21, 2016
HVAC Heating & Cooling Condenser Fan Issues Jun 27, 2015
HVAC Heating & Cooling Which condenser would you use? Apr 3, 2014
HVAC Heating & Cooling Condenser fan noise and then blade breaks. Advice Please. Sep 28, 2013
HVAC Heating & Cooling A/C Condenser Anti-vibration Isolation Pads Aug 9, 2012
