Condensation on basement pipes
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by coopns, Jun 9, 2008.
  1. coopns
    coopns New Member
    Sep 25, 2006
    Massachusetts
    Just moved in so seeing lots of new situations...
    In basement I saw a few copper pipes that had some condensation...little drips of water coming off them. I had all the windows in the basement closed but did open one window. It was very hot and humid just outside of Boston. Does that sound right? Why were some pipes dripping a bit while others weren't? And should I keep the basement closed and run the humidifier or open all the windows?
  2. speedbump
    speedbump New Member
    Jul 15, 2005
    Water well and pump tech.
    Riverview, Fl.
    The reason some were dripping was that water was run through those pipes recently. The cold water is what starts the dripping. You could use Pipe Wrap to insulate them. That would stop the dripping.
    bob...
  4. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    There are several comments to be made here.
    Water will condense on pipes when the dew point temperature is at or above the temperature of the water in the pipes. Water condensing on some pipes and not others indicates that wate is being used on those lines. The incoming water in those pipes has not warmed to room temperature. Sometimes this can also indicate water leaking such as a running toilet or, leaking faucet. Make sure that you are not wasting water!
    Insulating the pipes can help prevent or, limit condensation.
    Water condensing on pipes is an indicator of very high humidity. I would suggest closing up the basement and running a dehumidifier to prevent mold and mildew.
  5. novicepiper
    novicepiper Not a Master Plumber
    Apr 29, 2008
    Freelance Industrail Multimedia Conceptualist - I
    CAN Toronto GTA
    i have the same issue
    So i have the same issues - i just thermal wrapped the outer basement walls and there seems to be condensation on the cold pipes (not insulated)- if i wrap said pipes (cold) & (hot just to help keep the hot water warm)- what are the chances of water gathering within the wraps inner wall and the copper pipes outer wall?
    Is there any danger of:
    corrosion
    mold
    leaks
    thanks in adavance novicepiper
  6. Redwood
    Dec 15, 2007
    Service Plumber
    Insulation creates a dead air space. This air will not have the moisture content to condense... The insulation keeps new moisture laden air from reaching the pipe to condense.
  7. novicepiper
    Apr 29, 2008
    CAN Toronto GTA
    thanks as always redwood
Similar Threads: Condensation basement
Plumbing Forum, Professional & DIY Advice condensation on a water pipe in basement Mar 31, 2006
Plumbing Forum, Professional & DIY Advice Where to drain water (condensation from HRV) Feb 8, 2017
Plumbing Forum, Professional & DIY Advice Well Water & Condensation Sep 2, 2016
Plumbing Forum, Professional & DIY Advice Cycle Stop valve and condensation Mar 28, 2016
Plumbing Forum, Professional & DIY Advice Condensation pump secondary runoff Aug 1, 2015
