Condensate trap.
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Alan Littlewood, Feb 15, 2005.
  1. Alan Littlewood
    Alan Littlewood New Member
    Feb 15, 2005
    Computer Eng.
    San Jose CA.
    I have an issue with the water draining away from my "High efficiency" heating furnace. Water is fed through a rubber hose into a "condensate trap" and then out through a plastic pipe to an outside drain. There is no pressure involved with this, it is simply a gravity drain away system.
    My question is about this "condensate trap" which is a cheap looking white plastic box with 3 inlets (I think) and one outlet.
    Can someone describe what is inside this box? Is it simply an empty cavity, or is there some form of valve inside?
    Many thanks for your help,
    Alan
Similar Threads: Condensate trap
Plumbing Forum, Professional & DIY Advice sink P-trap with hvac condensate drain Jan 14, 2014
Plumbing Forum, Professional & DIY Advice Condensate drain line as trap prime Dec 22, 2005
Plumbing Forum, Professional & DIY Advice Condensate Standpipe Nov 4, 2016
Plumbing Forum, Professional & DIY Advice AC Condensate Drain Question May 30, 2016
Plumbing Forum, Professional & DIY Advice Washer Floods Into Kitchen Sink & Rerouting Furnace Condensate Drain Jan 26, 2016
