Condensate Pump tie into DWV
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Lakee911, Sep 21, 2005.
  1. Lakee911
    Lakee911 I&C Engineer (mostly WWTP)
    Aug 23, 2005
    Columbus, OH
    Hi all,
    Curious to see what you guys recomend for using DWV for drain for a condensate pump. Is this the correct procedure? Condensate Pump Drain to air gap to P trap to DWV system? Any better ideas? Air gap needed? If Condensate drain (from A/C) has a trap, do I still need the airgap and trap after the pump?
    Thx
    Jason
  2. hj
    pump
    The pump makes the condensate connection from the AC an indirect connection so it does not need a trap. The pump should have a check valve on its discharge connection, so you can make any type of connection to the DWV that will work.
  4. Lakee911
    Aug 23, 2005
    Columbus, OH
    Oh ya, it does. Thanks
    Jason
Similar Threads: Condensate Pump
Plumbing Forum, Professional & DIY Advice Connecting condensate pump to tub overflow pipe Sep 17, 2013
Plumbing Forum, Professional & DIY Advice Basement dehumidifier/ condensate pump Aug 6, 2010
Plumbing Forum, Professional & DIY Advice Condensate pump output Dec 12, 2009
Plumbing Forum, Professional & DIY Advice Help with condensate pump outlet Jan 28, 2009
Plumbing Forum, Professional & DIY Advice Condensate Pump for Water Softener May 29, 2007
