Condensate drain tankless hotwater tank
Discussion in 'Tankless Water Heater Forum' started by yngwie_69, Mar 28, 2014.
  1. yngwie_69
    yngwie_69 New Member
    Sep 8, 2009
    Prince Rupert, BC
    Help me with condensate line, I was told to just run it through the wall outside, but i hear storys of the line freezing and plugging up. and i heard the condensate eats away abs pipe. I put a neaturalizer filter inline, and a over flow if it plugs up, there is a floor drain close by to, if the main sewer backed up it would come out the floor drain. What is the proper way to run the condensate line? will this work? I also heard laundry soap nuturalizes condensate to.
    Ohh and the laundry drain is way lower then in the picture, like 2 feet between the tees
      File size:
      19.1 KB
      333
  2. jadnashua
    There are a bunch of condensate pumps, and if the outlet is lower than the top of the laundry box, I'd get one, and run it into there. Little Giant makes a bunch of different pumps, and most of them aren't all that expensive.
  4. cicerored
    cicerored New Member
    Aug 21, 2008
    Clay, New York, United States
    My understanding is that the condensate is about a acidic as orange juice or soda. It is not immediately caustic. The only thing I am not sure about is the ABS issue, because we use PVC here. But, if you have installed a neutralizer, you can safely drain it to any household drain. By your picture, it looks as if you can drain it by gravity. By the way, the plastic pipe provided with the units for moving the condensate from the unit to the drain is very thin, cheap plastic. It is way less durable than any abs or PVC. If the companies are comfortable with providing this to the customers, I am sure your abs pipe would last about a million times longer.
  5. yngwie_69
    Sep 8, 2009
    Prince Rupert, BC
    used 1/2 inch sch 40 pvc for the condensate.
Similar Threads: Condensate drain
Tankless Water Heater Forum Condensate Drain Line Nov 4, 2013
Tankless Water Heater Forum Newer Tankless Technology - Venting & Condensate Dec 16, 2016
Tankless Water Heater Forum Tankless Water Heaters - Practical for Seasonal Cottage where water is drained? Jan 28, 2011
Tankless Water Heater Forum FYI - Drain Pan for Tankless Dec 23, 2009
