Condensate Drain Line
Discussion in 'Tankless Water Heater Forum' started by Homewrecker44, Nov 4, 2013.
  1. Homewrecker44
    Homewrecker44 New Member
    Nov 4, 2013
    Toronto
    Hey All, first post here.
    I've got a new construction home that is almost complete. I've had the builder install a Rinnai Tankless unit and when I was there last I noticed that they ran the condensate drain along the floor to the floor drain and fastened it over the drain grate with some wire. They also did the same for the furnace condensate line.
    I don't know why builders don't just run these under the concrete for a cleaner look. Anyway, I noticed that I have an unused Floor Drain Primer Tube (there's 4 in total) protruding above the concrete and was wondering if I could just move the condensate line so that it drains into this Primer Tube. Everything ends up going into the floor drain anyway so I figured this wouldn't be an issue.
  2. Caduceus
    Caduceus Master Plumber
    Oct 16, 2013
    Just a Plumber
    Pittsburgh, PA
    If you can, post some pictures of the primer pipes and condensate drains.
  4. Homewrecker44
    Nov 4, 2013
    Toronto
    I won't be able to get back there for a week or so to get some pics.
    The Condensate Drain Lines are clear flexible hose (not sure what material). The Primer Pipes are a Black flexible material approx. 1/2" in diameter. These might be ABS.
Similar Threads: Condensate Drain
Tankless Water Heater Forum Condensate drain tankless hotwater tank Mar 28, 2014
Tankless Water Heater Forum Newer Tankless Technology - Venting & Condensate Dec 16, 2016
Tankless Water Heater Forum Tankless Water Heaters - Practical for Seasonal Cottage where water is drained? Jan 28, 2011
Tankless Water Heater Forum FYI - Drain Pan for Tankless Dec 23, 2009
