Concrete Subfloor
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by angelbaby7898, Sep 7, 2009.
  1. angelbaby7898
    angelbaby7898 New Member
    Aug 21, 2009
    Southern New Mexico
    We are in the process of tearing out our bathroom. Figured if we were needing to re tile our shower might as well make it bigger while I'm at it. We have a concrete subfloor and in opening the walls have found a plumbing pipe in the way of were I wanted to expand the shower. Can someone please explain the process of moving plumbing in concrete. How exactly do I repair the subfloor when done?
    Thanks
  2. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    You probably will need professional help on this one. Anytime you have to cut or break concrete you are venturing very close to te point where DIY is no longer appropriate. Not that it can't be done, but there are possible risks to the structure of the concrete, it is a fairly difficult job without proper tools and know-how. It is almost impossible to give specific advice on something like this without being on site to examine the entire picture. It would be wise for you to consult local professionals before proceeding.
  4. Herk
    Herk Plumber
    Oct 28, 2007
    S.E. Idaho
    Again and again I have tried to explain the proper way to pan a tile shower. I have never found an owner or other tradesman who really cares. And of course they fail. This is for pros. Why spend a fortune on tile only to have it wrecked in a year or two?
  5. hj
    water line
    The easy answer to your question is that it is not likely that YOU can do it. Normally a situation like that is going to require that the line be cut and extended under the floor and that requires a BRAZED joint that few DIYers are capable of doing.
  6. jadnashua
    For the drain, you could couple the drain pipe to plastic with the proper fitting after cutting off the original trap and then extend in plastic and put in a new trap where it needs to be. Water is tougher.
    There are all sorts of ways to build a proper shower, and probably more that will cause it to fail. For help on how to build one that will last, check out www.johnbridge.com. Personally, I like the Kerdi system from www.schluter.com.
  7. angelbaby7898
    Aug 21, 2009
    Southern New Mexico
    Thanks, I do plan on using Kerdi... I guess my main question was really how to repair the subfloor :confused:
  8. iminaquagmire
    iminaquagmire DIY Senior Member
    Dec 16, 2007
    FF/EMT
    1) Refill with dirt and then gravel to the bottom of your existing slab.
    2) Replace any damaged or missing vapor barrier that may be beneath the slab to the best of your ability.
    3) You'll want to drill holes in the edge of the concrete around your opening, then insert rebar pieces. This will tie your patch and existing concrete together.
    4) Mix and pour your concrete, screed off excess, trowel with a magnesium float to settle the aggregate and bring the cream to the top. Let it set a bit, then come back and finish trowel with a steel trowel or put a broom finish on.
  9. jimbo
    jimbo Plumber
    One problem that has been posted by more than one unsuspecting DIY'er ( or even a contractor ) is accidentally cutting a wire in post tension slabs. That will not make your day!
  10. angelbaby7898
    Aug 21, 2009
    Southern New Mexico
    Thank you...
    With more demo work completed I've discovered the shower floor was sunken in, the concrete was broken away to do this and the deck mud is just on the dirt... I just have no idea why someone would have done that.
    Thanks for all the advice, I really appreciate it.
Similar Threads: Concrete Subfloor
Plumbing Forum, Professional & DIY Advice Subfloor instead of breaking concrete? Jan 23, 2007
Plumbing Forum, Professional & DIY Advice Sealing pipe through concrete Yesterday at 11:26 AM
Plumbing Forum, Professional & DIY Advice Can PVC be encased horizontally in concrete Sep 6, 2016
Plumbing Forum, Professional & DIY Advice Best way to raise steel tub off concrete floor? Aug 28, 2016
Plumbing Forum, Professional & DIY Advice Sewer cleanout (and cover) in concrete Jul 31, 2016
