concrete shower base removal
Discussion in 'Remodel Forum & Blog' started by lawilliams, Oct 12, 2004.
  1. lawilliams
    lawilliams New Member
    Oct 12, 2004
    concrete shower base removal or salvage?
    I am trying to remodel my bathroom and am stuck on how to remove/ salvage my concrete shower base. I have removed the ceramic tile and now have just the base. Is it possible to keep the base and simply re-tile or am I going to have to re-do the base? Any suggestions on how to do either would be great b/c I have absolutely no idea.
  2. LonnythePlumber
    LonnythePlumber Plumber, Contractor, Attorney
    Sep 6, 2004
    Wichita, Kansas
    John Bridges where Are You?
    You may want to go to Terry's friend's site, I don't see any sense of trying to save the pan but some of the tile setters there feel you don't always have to tear it out.
  4. hj
    If the old base had a membrane liner, then the concrete should come out easily once it is cracked into smaller pieces. If it does not have a liner, then the concrete should be removed and one installed. For the relatively small cost involved, I would never trust an old liner, (especially since it could have been damaged while removing the tiles), and redoing it afterwards would require starting over.
  5. lawilliams
    Oct 12, 2004
    Thank You!
    Thanks for the responses. The site is exactly what I need as again I really don't know what I'm doing. Appreciate it.
Similar Threads: concrete shower
Remodel Forum & Blog Attaching to a concrete block wall Jul 12, 2016
Remodel Forum & Blog Concrete slab woes; need new water lines, radiant heat is leaking. Apr 24, 2016
Remodel Forum & Blog Sealing vertical pipe penetrations through Concrete? May 20, 2015
Remodel Forum & Blog Foil faced foam over concrete in walkout basement ok? May 14, 2015
Remodel Forum & Blog best tile to concrete cement Jul 1, 2014
