Concrete fill splashed onto new acrylic tub! How to remove?
Discussion in 'Shower & Bathtub Forum & Blog' started by LynnRowe, Nov 29, 2013.
  1. LynnRowe
    LynnRowe New Member
    Nov 26, 2013
    Vancouver BC
    My tiler did a superb job tiling my bathroom today. He also used concrete fill to level the floor to prep for the tiling tomorrow.
    I noticed tonight when I went to check the tiling that there were light splashes of the fill on the side of my new acrylic bath tub...please tell me this will just wash off!
    If not, I guess my GC will be a rather unhappy man when he has to get his trades to rip out the new tile, rip out the new bath tub, and replace it all.
    I won't be very happy, myself.
  2. johnfrwhipple
    johnfrwhipple BATHROOM DESIGN & BUILD for both Canada & the US
    Jul 20, 2009
    Design Work World Wide: Bathrooms Vancouver Area
    North Vancouver, BC
    Lynn most times these splashes are pourly bonded to the substrate or tub in this case.
    I would get a sponge and soak it.
    Then prop it up against the spill and leave it there for a good 30-60 minutes. Then try and remove the fill with a scraper. I use an old 2" wall scraper with a super flat edge. You can use a stick. A straight razor. Anything.
    The key here is to not scratch the tub with the tool. Often a stick is the safest and with just a little pressure (after the soak) the cement should pop off.
    Good luck.
    [​IMG]
    [​IMG]
    Same principle used here in the last two pictures. A blob of drywall compound I dropped by mistake in picture one on the frameless glass while doing drywall touch ups. I left the rag there for a good two hours and then with no effort wipped the drywall compound off the glass.
    JW
  4. jadnashua
    Is there a hidden area you could test? All cement is dissolved by acids...vinegar will do it. But, you don't want the vinegar to etch your new tub...it probably won't but is it safer to test it in a hidden spot. Depending on how cured the cement is, more water won't do much. If it is quite new, it may, but if vinegar won't etch your tub, it will eat the concrete even if it is years old. Careful when you wash it off, the sand in the mix will NOT dissolve in the same way the calcium based cement will, and you don't want to scratch things with the sand that will be left if you rub it.
  5. LLigetfa
    Feb 6, 2011
    Information Technology
    NW Ontario, Canada
    +1 for using vinegar.
  6. LynnRowe
    LynnRowe New Member
    Nov 26, 2013
    Vancouver BC
    Thanks guys, I did the soaked sponge trick and it worked! However...OMG you wanna talk about the WORST tile job EVER??! I am beyond words...! He cut several of my beautiful 3x6" marble tiles to force-fit into a herringbone pattern, and did so with some kind of hand saw, which left crooked jagged edges, rounded (relatively speaking) corners, sheared surfaces...the tile level is uneven, I can tell by sight; the grout lines are unbelievably uneven, as is the grout depth.
    Called my GC and told him it all has to be taken out and redone properly. I just sent him photos, and they are far from pretty. :(
  7. johnfrwhipple
    Jul 20, 2009
    North Vancouver, BC
    Ooouch.
    Did you outline your expectations prior to the tile being installed?
    Did you ask for and sign off on a tile mock sample board?
    These two things are so important right from the very beginning of every renovation...
Similar Threads: Concrete fill
Shower & Bathtub Forum & Blog Cast Iron Shower drain on concrete Yesterday at 2:58 PM
Shower & Bathtub Forum & Blog Concrete shower pan; do I need a liner? Feb 14, 2017
Shower & Bathtub Forum & Blog Shower installation over a sump pit in a concrete floor with radiant heat Jan 1, 2017
Shower & Bathtub Forum & Blog DO I NEED TO INSTALL SHOWER PAN FOR A SHOWER ON A CONCRETE FLOOR? Nov 30, 2016
Shower & Bathtub Forum & Blog Shower Pan: No concrete underneath plastic pan by orig bldr Nov 19, 2016
