Jerry Meeker
I have several supply line shutoff valves in my master bathroom that are corroded, and I decided to replace them before they caused any issues. They are typical 5/8 OD valves with compression fittings connected to copper supply lines. When I removed the valves, I had difficulty removing the old compression sleeves and nuts. I decided to try my luck in re-using the old sleeves and nuts. After carefully applying thread tape and installing the new valves, I was left with several connections with slow leaks.
I ordered a special tool on the internet that is designed to remove the old sleeves and nuts. The tool worked well, but when the old sleeve was removed, it revealed that the copper supply line had some grooves where the sleeve sat, probably because the connection had been over-tightened. Now, even with a new sleeve and nut, I still can't get a drip-free connection.
My question is this: can the supply line be repaired without tearing out the drywall? Is this a reasonably straight-forward job for a professional plumber? Can you describe the steps that would be taken to make the repair? Thanks in advance for your feedback!
