DW85745
I have a case where the 1/2 copper supply line is somewhat short coming out of the wall and currently has a cap on it. I planned to remove the cap and put a compression stop value on the end, but raised a question in my mind whether the compression ring would seal properly over the silver solder (naturally the pipe will be wiped as clean as possible to remove any excess solder).
Question: Will a compression fitting work in this case?
