Compression or Solder Fitting
Discussion in 'Shower & Bathtub Forum & Blog' started by GoldMaple, Aug 27, 2009.
  1. GoldMaple
    GoldMaple DIY Junior Member
    Jul 11, 2009
    Edmonton, Alberta
    Does it matter if one uses a compression or a solder fitting for use as a bathroom shut off valve? Just two valves that shut off the shower, sink and toilet in the bathroom. Is there any reason not to use a compression fitting?
  2. flamefix
    flamefix New Member
    Sep 4, 2009
    Heating engineer in the UK licensed to fit service
    Exeter, England
    Only serviceability issues, which would be easier to replace..
  4. hj
    valve
    Only servicability issues. Which will be most likely to leak and require replacement. Use the solder valve.
Similar Threads: Compression Solder
Shower & Bathtub Forum & Blog Need vintage compression nut Mar 20, 2016
Shower & Bathtub Forum & Blog Persistent shower leak after Sayco compression valve rebuild Nov 2, 2015
Shower & Bathtub Forum & Blog Upgrading shower stems from compression to quarter-turns May 9, 2015
Shower & Bathtub Forum & Blog Pfister - Change Compression to Ceramic? Feb 9, 2014
Shower & Bathtub Forum & Blog Fiberglass shower base with compression drain Mar 23, 2010
