compression nut leaking on cold water to sink
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by firsttimer, Sep 6, 2005.
  1. firsttimer
    firsttimer New Member
    Aug 30, 2005
    I have a shutoff valve attached to the cold water (copper) line running up to vanity sink. Its connected via compression nut. I'm wondering if i've compressed too far? or not far enough? I have a steady leak of water droplets out of there, i'd say 5 drops per min? do i need to keep tightening or have i "ruined" the connection and need to re-cut the copper and reinstall a new compression valve?
  2. Terry
    Aug 17, 2004
    Compression fittings.
    It should have sealed as long as you either installed it out of the box, or sprayed some WD40 on the threads.
    If you used Teflon tape or paste, you will want to remove that.
Similar Threads: compression leaking
Plumbing Forum, Professional & DIY Advice Advice wanted on dealing with leaking compression fitting Feb 20, 2015
Plumbing Forum, Professional & DIY Advice Leaking compression connector PEX hose under sink Jun 12, 2010
Plumbing Forum, Professional & DIY Advice External Frige Water Filter - compression fitting leaking Oct 15, 2008
Plumbing Forum, Professional & DIY Advice leaking 1/4" compression fitting on angle stop Jan 29, 2007
Plumbing Forum, Professional & DIY Advice Compression shutoff leaking.. Help please! Jun 6, 2006
