compression fittings
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by don metzinger, Jan 7, 2007.
  1. don metzinger
    don metzinger New Member
    Sep 17, 2005
    I recently had to re-use the old ferrules when installing some replacement valves and had trouble getting them to re-seal, finally got them set. Is it adviseable to use eiter teflon tape and or paste over old ferrules? I have never had any problems with new ones. Does anyone use tape or paste with either new or old?? Thanks - Don
  2. kordts
    kordts In the Trades
    Oct 15, 2005
    industrial service plumbing foreman
    exurban Chicago
    Do not use anything on compression fittings, maybe a drop of oil.
  4. don metzinger
    Sep 17, 2005
    Thanks, I was told to not use anything and have followed that advise but was wondering why? - Don
  5. norcal1
    norcal1 Plumber/Owner
    Jan 24, 2005
    Same reason you shouldn't fix a leak with duct tape. :)
    BTW: I like to use a little plumber's grease on the threads...
  6. Randyj
    Randyj Master Plumber
    Nov 25, 2006
    Alabama
    Because once the first connection is made to the ferrule it is like a finger print....virtually every fitting is different and the odds of getting the same old one EXACTLY in the original place at the exact same angle is very low odds so you can bet on having a leak. Sometimes you can tighten extra good to stop the leak but you may damage the nut or the fitting/valve... The ferrule is a soft metal but it still is hard to get it to seal once it is deformed by the original compression.
  7. hj
    ferrules
    Tell that to the hundreds, and thousands, of ferrules I have reused by just connecting the old nut to the new valve. Tighten them with a 15/16" open end wrench and you will not distort them and will not have to overtighten them.
  8. Randyj
    Nov 25, 2006
    Alabama
    hj... me too...but the guy wants an explanation... maybe I should edit that post to be a little more liberal... I definitely would not take a ferrule off of a pipe and re-use it on another pipe. Maybe I got up too early this morning.... time to get out to work... I've got to re-key a whole house and run 250' of conduit underground for multiple phone lines.... might be a long day. Too bad I don't get intelligent and stick to just one occupation...but then I don't pass up a buck!
  9. SteveW
    SteveW DIY Senior Member
    Feb 11, 2005
    Omaha, NE
    The reason is that the seal is actually made by the ferrule mating with the spherical female part of the fixture, and NOT by the threads. Teflon tape or thick pipe dope can interfere with the ability of the nut to fully thread far enough on the male threads to adequately compress the ferrule.
  10. don metzinger
    Sep 17, 2005
    Thanks, I appreciate all the info. - Don
  11. SteveW
    Feb 11, 2005
    Omaha, NE
    You're welcome! I learned that little fact, along with dozens of others, on this site - great place to check in on regularly.
  12. Mike Swearingen
    Mike Swearingen New Member
    Jan 12, 2005
    Independent Real Estate Broker
    On Albemarle Sound In Northeastern NC
    I'm not a pro plumber, but I've been DIYing it for more than 50 years.
    Who says that you can't use anything on a used ferrule?
    I've been smearing used ferrules with a small dab of caulk for years to seal them (with new and old nuts). Works like a charm. No leaks. No problems.
    Mike
Similar Threads: compression fittings
Plumbing Forum, Professional & DIY Advice Compression fittings for 3/4" and 1" Jul 12, 2016
Plumbing Forum, Professional & DIY Advice Compression fittings and brass pipe Feb 22, 2014
Plumbing Forum, Professional & DIY Advice What makes compression fittings leak? Oct 6, 2013
Plumbing Forum, Professional & DIY Advice Can Compression Ring Be Used With 'Speedi Adapter' Fittings? Aug 14, 2013
Plumbing Forum, Professional & DIY Advice Faucet was loose and moved a bit...Are my compression fittings OK? Aug 24, 2012
