Compression fittings and brass pipe
Discussion in 'Plumbing Forum, Professional & DIY Advice, Tips & ' started by Gravity, Feb 22, 2014.
  1. Gravity
    Gravity New Member
    15
    Norwood, MA
    Hi, I was going to install shutoff valves on existing 1/2" brass cold and hot water lines. Can I use valves with 1/2" compression inlets? Do they play nice with brass pipe? Or should I use 1/2" sweat connection?
    If I sweat it, is there any need to modify my copper pipe soldering technique for brass pipe?
    And before anyone mentions it, I know PEX is awesome and the greatest thing since sliced bread, blah blah blah but it isn't in the budget for this renno.
  2. Terry
    14,939
    A threaded brass nipple needs threaded stops.
    1/2" copper can use either sweat on stops, or compression.
    1/2" copper is 5/8" OD
    [​IMG]
  3. Gravity
    Gravity New Member
    15
    Norwood, MA
    Thanks for the response, Terry.
    As a hypothetical, what if I cut back existing brass pipe with a sawsall and there was no threaded end left? Could you use compression on that?
    Thanks again.
  4. Terry
    14,939
    I would not do that.
    I'm not aware of a compression fitting for those. There are plenty of stops that thread on though.
    It's an easy job to spin on a new stop.
  5. Gravity
    Gravity New Member
    15
    Norwood, MA
    Excellent, thank you Terry!
    Best,
    Mike
  6. hj
    26,534
    There are no "compression", or solder, fittings for brass pipe. They are threaded and screwed. What are you trying to do? How about a picture, in case you are describing the task improperly?
  7. dj2
    dj2 Member
    409
    California
    I suspect that the OP cut off the thread on the brass nipple.
    If that's the case, unscrew the brass nipple and replace it with a new one.
  8. hj
    26,534
    If thatis case, then it was a "do something even if it is wrong" action/reaction.
  9. Gravity
    Gravity New Member
    15
    Norwood, MA
    Thanks guys. I'll just spin on a new top as Terry suggested.
    I am actually just in the planning stages of a small kitchen renno and the 1/2" cold and hot water pipe under the sink is brass so I was just wondering if I could just cut the pipe back with a Sawsall and get new shutoffs with 1/2" compression fitting connections to be used on the brass pipe. I know enough about plumbing to be dangerous but everything in my house is so different from modern construction standards that I always make sure I come here before putting saw to pipe!
  10. jadnashua
    21,947
    What is the OD of the brass pipe? The stuff is pretty stiff, so a compression fitting probably wouldn't seal, even if the size was okay.
    FWIW, in MA, doing ANY plumbing without a license and a building permit can get you into hot water, so beware.
Similar Threads: Compression fittings
Plumbing Forum, Professional & DIY Advice, Tips & What makes compression fittings leak? Oct 6, 2013
Plumbing Forum, Professional & DIY Advice, Tips & Can Compression Ring Be Used With 'Speedi Adapter' Fittings? Aug 14, 2013
Plumbing Forum, Professional & DIY Advice, Tips & Faucet was loose and moved a bit...Are my compression fittings OK? Aug 24, 2012
Plumbing Forum, Professional & DIY Advice, Tips & Can Teflon tape (PTFE) cause leaks on compression fittings? Feb 27, 2012
Plumbing Forum, Professional & DIY Advice, Tips & Frod compression fittings concerns Jan 21, 2012
