Wrex
A few days ago the saddle valve on my fridges ice maker leaked.
What a mess after I shut the water off I decided to do it the right way by sweating in a T and installing a REAL valve so that I wouldn't have to deal with this again.
Unfortunately upon further insepection whoever originally installed the ice maker tubing didn't take much care while bending the copper tubing it was horribly kinked in certain places so I decided to replace the tubing as well.
Soldering is like second nature to me and that went quickly as did running and carefully bending the tubing. However I had a real issue with those pesky compression fittings.
I had some minor weeping coming from the compression fitting by the fridge I made very sure that the pipe was straight into the seat on the solenoid valve and securely clamped to the fridge body.
Tightening in an attempt to stop this weeping eventually deformed the ferrule (why I hate these fittings) and I had to cut the pipe and start over.
Frustrated with this I searched for an answer and found an answer in a Bob Vila video on a website the plumber did something that I didn't think of.
He said to wrap the ferrule with 3 turns of teflon tape to stop these pesky leaks.
Sure enough it worked the first time not even a drop of water weeping.
I use teflon tape all the time on threaded pipes but I never would have thought of using it like this.
I was just wondering if anyone else knew of this trick or uses it?
