the homeowner
- Messages
- 3
- Reaction score
- 0
- Points
- 0
I have a question to leave in your hands for a selection of 2 Toto toilets. Bath 1 (lav, toilet dimensions are 2'5"wide X 2'9" deep, shower) is to be round front standard height, or would you even recommend an elongated based on the dimensions previously set forth? - Aquia II or UltraMax, and bath two (lav, toilet bath/shower) is to be elongated and of a higher height - Aquia III, UltraMax, Soiree, Guinevere or Carlyle.
For bath 2, do you think for how much visible side area there is to have the skirted bowl?
If all are not double siphon, should a double siphon be selected?
Regarding jets, are they angled or straight?
How do jets compare with cyclone?
Unifit setting prone to become weak/brittle, fail in later years if have to take off toilet from floor?
G-Max v. Dual-Max v. Double Cyclone?
Why is Aquia only 1 year compared with 5 year?
Should you see these be more prone to difficulties/failure, is the replacement available?
Can it be done without removing the tank since the system is in the middle of the tank?
Flushing rank best to worst - bath 1: Aquia II or UltraMax?
. bath 2: Aquia III, UltraMax, Soiree, Guinevere, or Carlyle?
Bowl Rinse rank best to worse - bath 1: Aquia II or UltraMax?
I hope that this may not only shed light onto my issues, but for those who are interested in purchasing similar lines as well, because over the last few days while on an expedition for the best Toto, I heard other similar concerns from other homeowners, some of which are their questions.
Thanks for everything!
