Comparing trane Furnaces
Discussion in 'HVAC Heating & Cooling' started by crabapplemcn, Mar 5, 2009.
  1. crabapplemcn
    crabapplemcn New Member
    Oct 29, 2008
  2. jadnashua
    One's a single stage burner, the other is a two-stage burner. The most comfortable heat is one that runs all the time. Since the winters aren't always super cold, for those mild days, the first stage is often enough to provide all the heat you need. Also, it's more efficient - same sized heat exchanger, but less heat going in means that it can extract more. The difference isn't all that much, but it's there...the bigger thing is the comfort level.
Similar Threads: Comparing trane
HVAC Heating & Cooling Comparing 3 Thermostats White-Rodgers, Lux and Jackson Jun 8, 2013
HVAC Heating & Cooling Comparing Heat Pump & Coil / Air Handler Brands Oct 12, 2011
HVAC Heating & Cooling Question on capacitor size on Trane AC unit Aug 6, 2015
HVAC Heating & Cooling Are the Motor Bearings Bad? Trane XL80 Feb 17, 2015
HVAC Heating & Cooling New Trane 2stage VS CAC...Ques about wiring Sep 8, 2012
