Combo ball valve/check valve for ejector pump...
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by hhcibtpaun, Jun 15, 2009.
  1. hhcibtpaun
    hhcibtpaun New Member
    Feb 17, 2009
    Pennsylvania
    Hey everyone,
    I am getting the parts together to finish up my basement plumbing. I am now at the point of getting the ejector pump and associated valves.
    I am going with the Zoeller M267 pump and I need to get a check valve and ball valve. Originally I was going to get the zoeller check valve and a standard issue ball valve, then I found this:
    [​IMG]
    This is about double what the separate pieces would be, so is it worth it? If any parts fail can they be replaced??? or do I have to replace the whole deal?
    Any help would be appreciated.
    Thanks...Mike
  2. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    That is a much better valve.
    Most check valves give a helluva thump when the pump shuts off.
    This one is quiet.
  4. hhcibtpaun
    Feb 17, 2009
    Pennsylvania
    Thanks...Mike
  5. hj
    valves
    If the ball valve fails you will have to cut it off the pipe and get a new one. Parts may or may not be available, so you might have to buy a new combo and use the parts from it if anything else goes bad.
  6. hhcibtpaun
    Feb 17, 2009
    Pennsylvania
    Thanks for the post. I ended up ordering, so now I just need to wait...
    Mike
Similar Threads: Combo ball
Plumbing Forum, Professional & DIY Advice Use of a double wye / combo tee vertically (everything vented) Aug 16, 2016
Plumbing Forum, Professional & DIY Advice Confirmation of DWV plan for laundry room/half bath combo Mar 9, 2016
Plumbing Forum, Professional & DIY Advice Leaking overflow pipe from combo cylinder Feb 18, 2015
Plumbing Forum, Professional & DIY Advice navien combo 240 water pressure Nov 20, 2014
Plumbing Forum, Professional & DIY Advice Double Combo Wye / Double Sanitary Tee / ?? Apr 22, 2014
