Combining Vent Pipes
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by supermattthehero, May 2, 2010.
  1. supermattthehero
    supermattthehero New Member
    Oct 13, 2009
    virginia
    I have four 1-1/2" vent pipes in my attic that I would like to combine into a single exit through the roof. What size should that pipe be, or how should I do it?
    Do the pipe sizes need to increase as they are combined (as with drain pipes)?
    Thanks
  2. shacko
    shacko Master Plumber-Gas Fitter
    Jan 22, 2006
    Rosedale, Md
    You can combine them into one 2in. vent. Do you have a larger vent in that area? if so you can run them into that if it's 3in. or larger.
  4. Winslow
    Winslow Plumber
    Dec 30, 2005
    Hawaii
    you can join them all together but the size after joining depends on what is attached to the individual vents, depending on which code you are under. According to the UPC you can join them all together under a 2" vent as long as the overall fixture units do not exceed 24.
Similar Threads: Combining Vent
Plumbing Forum, Professional & DIY Advice Combining vents. Please proof my layout. Jun 6, 2014
Plumbing Forum, Professional & DIY Advice Combining vents in attic Jul 27, 2013
Plumbing Forum, Professional & DIY Advice Combining Bathroom Ceiling/Drain Vents Oct 8, 2005
Plumbing Forum, Professional & DIY Advice Combining 3x3x2 wye + 1/8 turn May 21, 2008
Plumbing Forum, Professional & DIY Advice Combining sink and toilet's water pipes? Oct 6, 2007
