Collapsed casing? Any solutions?
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by MarkMCM, Jul 1, 2013.
  1. MarkMCM
    MarkMCM New Member
    Dec 1, 2010
    Arlington, Texas
    4" pvc cased well.
    200' deep
    static water level 60'
    well is approximately 30 years old.
    Old pump went out and was unable to be pulled, pvc broke at pump. Pump is at the bottom of the well.
    New pump will not go past 100'.
    Well is really unusable due to decreased available water. We have gotten a camera and a spear past the constriction.
    Are there any solutions other than drilling a new well? The two well guys that have been out don't offer anything other than a new hole.
  2. craigpump
    craigpump Well-Known Member
    Apr 12, 2012
    Self employed water system tech
    My first question is what caused the casing to collapse?
    Did the pump guys try to get a 3" Grundfos pump past the tight spot?
  4. MarkMCM
    MarkMCM New Member
    Dec 1, 2010
    Arlington, Texas
    Thanks for the reply. The consensus on the casing problem seems to be minor earthquake activity in the area.
    Nobody mentioned a 3" pump. Could we pull the present pump and use a 3" diameter weight to assess clearance?
  5. craigpump
    Apr 12, 2012
    Yep, I would try a weight 3" in diameter before I bought the 3" pump just to be sure. You might find a pump guy who has a used one you could try too.
  6. Texas Wellman
    Texas Wellman In the Trades
    Feb 9, 2010
    Owner of a Water Well and Pump Repair Business
    SE Texas-Coastal
    After re-reading your post, I think a 3" pump would probably be the solution. Have your well guy blow the well to see what it makes. I would look for at least 10 GPM before I would mess with the old well, and if it makes any sand or sediment then scrap it.
    Good luck.
  7. MarkMCM
    MarkMCM New Member
    Dec 1, 2010
    Arlington, Texas
    Thanks guys.
    We tried a 3" weighted pipe and got it past the constriction and then...
    We got the new 3" pump (Grundfos 10SQ10-290) to depth and we are back to original flow. That is the good news.
    Bad news. The Pumptec, after running for 5 minutes or so, shows Load and Voltage lights flashing, denoting a "rapid cycle".
    What gives? My well guy says, "Pumptecs don't work on 3"pumps." and "Those 3" pumps don't last very long anyway."
    I find both of those statements hard to believe. HELP! We need to get the Pumptec back in-line.
  8. craigpump
    Apr 12, 2012
    Pump Teks and 3" Grundfos pumps are not compatible, remove the Pump Tek.
    Those little Grundfos pumps are pretty good units, I have seen some go 10 plus years.
    Don't let it run dry.
  9. MarkMCM
    MarkMCM New Member
    Dec 1, 2010
    Arlington, Texas
    Any suggestions on pump protection? We have a low pressure cutoff on the line now.
  10. craigpump
    Apr 12, 2012
    I don't think there is anything like a Pump Tek for the 3" Grundfos.
  11. MarkMCM
    MarkMCM New Member
    Dec 1, 2010
    Arlington, Texas
    Thanks. I guess we'll see how things go with the low pressure cutoff.
  12. LLigetfa
    Feb 6, 2011
    Information Technology
    NW Ontario, Canada
  13. MarkMCM
    MarkMCM New Member
    Dec 1, 2010
    Arlington, Texas
  14. craigpump
    Apr 12, 2012
    Ask valveman
  15. LLigetfa
    Feb 6, 2011
    NW Ontario, Canada
    I tried pinging him but he appears to be offline now.
  16. valveman
    Mar 15, 2006
    Pump Controls Technician
    Lubbock, Texas
    Sorry. Traveling. Cycle Sensor works fine with SQ.
  17. MarkMCM
    MarkMCM New Member
    Dec 1, 2010
    Arlington, Texas
    That is some encouraging news. Thanks.
Similar Threads: Collapsed casing
Pumps and Tanks Well Forum & Blog. Water is life. Suggestions on well with collapsed Casing May 17, 2016
Pumps and Tanks Well Forum & Blog. Water is life. HELP!! 9oo foot well collapsed Aug 27, 2015
Pumps and Tanks Well Forum & Blog. Water is life. Collapsed Well Jun 7, 2015
Pumps and Tanks Well Forum & Blog. Water is life. Collapsed Well Need Opinions Feb 5, 2015
Pumps and Tanks Well Forum & Blog. Water is life. Need help ID'ing the well/casing Please! Jan 27, 2017
