Cole Massy PM60 connections
Larry Fostano
New York
I have a Cole Massy PM60 softener, my question is about head pressure . I would like to know if I can safely push my regeneration water up 3 feet then continue some 30 feet across a basement ceiling into a drain pipe that goes out the wall into a catch basin? My concern is that I do not want to put undue stress on the system , considered putting a check valve in but don't think that would be a wise idea . Thanks
ditttohead
Water systems designer, R&D
Ontario California
The vast majority of softeners can handle the water going up. The simplest way to do the math in your head is...
Venturi injectors require a differential pressure. Water going up puts back pressure on the injector thereby reducing their ability to perform. Water going up has about 1 pound of back pressure for every 2 feet of height (please don't argue the math.... it is just a simple way to get close enough). So by going up even 8 feet, you are only causing 4 psi of back pressure on the venturi. Assuming your water pressure going in to the injector is 50 psi, you should be just fine.
Some odd softeners in the past could not handle the drain lines going up but these are very rare. I believe the Siata Valve was one of them.
Bannerman
Ontario, Canada
While not pertaining to your original question, in consideration to your location, there is potential for any water which may not fully drain from the external drain pipe, freezing and blocking that pipe.
Why not just discharge your softener into the sewer or septic system as is most common?
