Cold Water!
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Cold Shower!, Oct 12, 2012.
  1. Cold Shower!
    Cold Shower! New Member
    Oct 12, 2012
    Virginia
    I got a new dishwasher hooked up last week and I got the new dual gas/electric stove hooked up today. I ran the first load in the dishwasher this afternoon. I have not turned on the stove for any extended amount of time today. The water throughout the house is heated with gas. Several hours after running the dishwasher and running one load of clothes earlier this afternoon - I tried to take a shower and was unable to get any hot or warm water at all. I waited several more hours and was not able to get any warm/hot water in any of the bathroom sinks. I would have figured that the water would have been warm at least by this time. I am not sure what to do. It does not seem that the hot water heater in the basement is heating - as I can usually hear the gas 'flame up' and heat the tank. Should I call the plumber back in the morning to address this issue. I was hoping to be done with spending money on the plumber - as all of the hook-ups this past week have been quite pricey. Thank you in advance for any advice.
  2. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    It would appear that someone did something wrong or didn't do something they should have done, but the root of the problem has to be at the water heater. A gas water heater should heat a tank of cold water in just a few minutes, not hours. I'd start with making sure the gas is turned on. If it uses a pilot light, it must be lit. If it uses an electronic ignition, then it must be plugged in. In my opinion, you should not have to pay the plumber if there was something he did or didn't do. If there is something wrong with the heater, that would be a different story, but I would not advise you to do more than a visual inspection of the heater.
  4. nestork
    nestork Janitorial Technician
    Aug 5, 2012
    Winnipeg
    I think Gary hit the nail on the head when he said "It would appear that someone... ...didn't do something they should have done,..."
    The plumber would have shut off the gas to hook up the stove. That woulda caused the pilot light on your water heater to go out while he was hooking up the stove.
    So, when he turned the gas back on to check that the stove was working properly, he figured he was finished cuz the stove worked fine. But, he forgot to relight the pilot light on the water heater.
    Just a guess, but it's my best guess. (and if Gary and I are right, then this one's a freebee)
  5. Gary Swart
    Sep 1, 2004
    Yakima WA
    I think that nestork has hit on the most likely problem.
Similar Threads: Cold Water
Plumbing Forum, Professional & DIY Advice Hot and Cold Pex Connections to the Water Heater from Below 59 minutes ago
Plumbing Forum, Professional & DIY Advice Broke my cold water stem for my shower. Options? Feb 14, 2017
Plumbing Forum, Professional & DIY Advice Moen shower head cold water only after shower remodel Jan 18, 2017
Plumbing Forum, Professional & DIY Advice Cold Water Line to Kitchen not Working Jan 9, 2017
Plumbing Forum, Professional & DIY Advice Cold water relief valve question Nov 11, 2016
