hi...
tried searching but couldn't find anything conclusive... i'm trying to figure out if my plumbing system has a problem... while doing maintenance on my tankless water heater i did the following...
- turned off the supply into the water heater
- turned off the hot water going out of the water heater
- turned on all hot water fixtures to let drain (except for laundry, dishwasher)
all the fixtures didn't shut off completely but still had a low flow to it... my single lever faucets had even more of a flow (naturally, i guess) and my first floor shower had a full blast (of cold) while my two other showers simply had the low flow...
- shouldn't there be zero flow coming out the dedicated hots since the output to the water heater is shut off?
- is cold water somehow getting into the hot water supply before it reaches the fixtures?
- could my first floor shower be the culprit somehow allowing the cold to feed back into the hot?
other notes
- my water heater is set to 135 (my plumber had to set it that high to reach satisfactory temps at the 2nd flr faucets)
- water heater is in basement
- copper piping uninsulated throughout
thanks in advance!
other notes
thanks in advance!
