Cold Air return on 2nd Level
Discussion in 'HVAC Heating & Cooling' started by Wave007, Sep 9, 2009.
  1. Wave007
    Wave007 New Member
    Sep 9, 2009
    Kitchener, Ontario
    I have a 2 story home which is approx. 70 years old. We have no cold air return on the 2nd level and are in the process of replacing the old furnace with a new one. My question is, is it a necessary to have a cold return on the 2nd level? If so what are the reasons. Also the cold air return on the main level is on the floor very close to the stairs going up.
  2. jadnashua
    Ideally, each room would have a return. In order to push air into a room, you need an outlet so it will flow. If you always leave the doors open, it isn't a problem. There's often enough room underneath a closed door, but that isn't always the case, especially if carpet is added, and there's now little to no clearance. This can lead to cold (or hot if a/c) rooms.
  4. Runs with bison
    Runs with bison Member
    Aug 23, 2009
    Midwest
    If there is not a return path in a room but it has an open register, then that room will tend to pressurize slightly. That will allow part of the air to escape underneath closed doors...or outside through any opening it can find (wall, window, attic.) As was already mentioned it will also reduce flow into the room (higher pressure to overcome) causing temperature differential with other sections of the home.
Similar Threads: Cold return
HVAC Heating & Cooling Chilly Finished Basement Needs Cold Return? Mar 26, 2014
HVAC Heating & Cooling Considerations for extending cold-air return Aug 2, 2012
HVAC Heating & Cooling Cold Air Return.... Jan 20, 2010
HVAC Heating & Cooling Cold air return? or not? Nov 15, 2009
HVAC Heating & Cooling cold air return sharp corners? Nov 4, 2009
