Code Question
Discussion in 'Electrical Forum discussion & Blog' started by jaxbldginspector, Sep 14, 2008.
  1. jaxbldginspector
    jaxbldginspector New Member
    Mar 19, 2008
    Does a washing machine need a dedicated circuit?
    Thanks again
  2. Alectrician
    Alectrician DIY Senior Member
    Jun 15, 2007
    Kind of a trick question.
    The laundry room needs one. The dryer can also be plugged into it.
    Can another outlet in the same room be on it????
  4. jaxbldginspector
    Mar 19, 2008
    I think I found the answer:
    NEC 220-4 (c) Laundry Branch Circuits-Dwelling Unit. In addition to the number of branch circuits determined in accordance with (a) and (b) above, at least one additional 20-ampere branch circuit shall be provided to supply the laundry receptacle outlet(s) required by Section 210-52(f). This circuit shall have no other outlets.
    Thanks
  5. jwelectric
    jwelectric Electrical Contractor/Instructor
    Jun 14, 2007
    Instructor
    North Carolina
    Are you still on the 1996 code cycle?
    What you have quoted is from that cycle!
  6. hj
    washer
    And, as an aside, here, when there is an electric dryer, the washer outlet is a single device receptacle so nothing except the washer can be plugged into it.
  7. jbfan74
    jbfan74 Electrical Contractor
    Jun 14, 2007
    Newnan, GA
    Do you have anything in writing to back up that statement?
  8. Speedy Petey
    Speedy Petey Licensed Electrical Contractor
    Jun 16, 2007
    NY State, USA
    I agree. If that is an actual code there must be a written amendment to back it up.
    That certainly is not an NEC requirement.
  9. hj
    outlet
    It is just the way the electicians do it, and they do the same with other outlets such as a freezer or garage wall air conditioner that should not be connected to a GFCI so that no one can plug an extension cord into the same outlet and not be GFCI protected while using it.
  10. Johnny C
    Johnny C Electrician
    Oct 19, 2008
    Elect Teacher, Consultant, Seminar Presenter, Elec
    Mass. & now Virginia Beach, VA
    Circuit for washing machine
    According to the NEC, it allows more than one receptacle outlet to be installed on the 20-ampere laundry branch-circuit. If you have a gas dryer, both the gas dryer and washing machine can be plugged into the same 20-ampere circuit, however, if the UL Labeling and Listing of the products specify that they must be on their own 20-ampere branch circuit, then 110-3(B) takes precedent.
Similar Threads: Code Question
Electrical Forum discussion & Blog Bathroom remodel code question Jun 7, 2016
Electrical Forum discussion & Blog Electrical code questions. 2005 NEC Jun 15, 2015
Electrical Forum discussion & Blog Code question 277 and 24 volts same fixture. Sep 27, 2012
Electrical Forum discussion & Blog Code Question: Safely Storing Future Use Wires Jul 31, 2012
Electrical Forum discussion & Blog Code question on multi-location dimmers ( lutron / maestro ) Dec 28, 2009
