Code Question for UF cable
Discussion in 'Electrical Forum discussion & Blog' started by Juan for the road, Aug 12, 2008.
  1. Juan for the road
    Juan for the road New Member
    Aug 10, 2008
    construction
    Northeast,USA
    What does the code specify as the minimum depth of burial for UF cable.The cable is 12/2 UF(direct burial).Burial in the trench will be unprotected.It will be protected with a 20a GFCI breaker.
    How many cables am I permitted to bury off of this circuit?
    What does the code call for, for protection ,as it makes it's way into and out of the ground?
  2. Billy_Bob
    Billy_Bob In the Trades
    Apr 2, 2008
    Basically everyone goes by the NEC. But certain areas have their own modifications to the NEC for this and that.
    One of these modifications could be differences in burial of electrical cables depending on the local ground conditions. For example some areas have permafrost. Others have a very high water table. Others lots of sharp rocks in the ground. Some areas have plenty of nice [non-wire damaging] sandy soil.
    So I would ask your local electrical inspector.
  4. Billy_Bob
    Apr 2, 2008
    P.S. Code or no code, I like wires coming out of the ground next to a house (outside wall) to be in conduit. This is for lawnmower/weedeater damage which can occur.
  5. Chris75
    Chris75 Electrician
    Aug 12, 2007
    Electrician
    Litchfield, CT
    The answer is 12"
  6. Billy_Bob
    Apr 2, 2008
    I'll tell ya... When I'm burying electrical cable, I like it to be deep (like at least 18 inches). I consider what else might be dug in that area in the future... Tree holes, sprinkler system, garden tilling, or even a dog digging! Then I am sure to go deeper than that.
    Some people recommend fence posts be installed 2 ft. deep for example (due to wind).
    But I live in an area where the ground is soft and easy to dig deep. I appreciate that in some areas like southern Arizona, the ground is so hard you almost need a jack hammer to break it up! (Actually I have heard of them doing that there.)
    If it is something like a sewer line, water line, etc. being installed in the future, they should have enough sense to find out where lines are already buried.
    It is a pain to dig a hole for something and cut an electrical line. I once saw where a guy was just smoothing out a road with a tractor and he cut a main telephone line. That line was not burried more than a few inches deep!
  7. Juan for the road
    Aug 10, 2008
    construction
    Northeast,USA
    This is referenced in the NEC,I believe.Code experts?
  8. jwelectric
    jwelectric Electrical Contractor/Instructor
    Jun 14, 2007
    Instructor
    North Carolina
    (D) Protection from Damage. Direct-buried conductors and cables shall be protected from damage in accordance with 300.5(D)(1) through (D)(4).
    (1) Emerging from Grade. Direct-buried conductors and cables emerging from grade and specified in columns 1 and 4 of Table 300.5 shall be protected by enclosures or raceways extending from the minimum cover distance below grade required by 300.5(A) to a point at least 2.5 m (8 ft) above finished grade. In no case shall the protection be required to exceed 450 mm (18 in.) below finished grade.
    (2) Conductors Entering Buildings. Conductors entering a building shall be protected to the point of entrance.
Similar Threads: Code Question
Electrical Forum discussion & Blog Bathroom remodel code question Jun 7, 2016
Electrical Forum discussion & Blog Electrical code questions. 2005 NEC Jun 15, 2015
Electrical Forum discussion & Blog Code question 277 and 24 volts same fixture. Sep 27, 2012
Electrical Forum discussion & Blog Code Question: Safely Storing Future Use Wires Jul 31, 2012
Electrical Forum discussion & Blog Code question on multi-location dimmers ( lutron / maestro ) Dec 28, 2009
