Code for mounting pipe to walls
Discussion in 'Plumbing Code Questions' started by TheNewGuy, May 16, 2014.
  1. TheNewGuy
    TheNewGuy New Member
    Apr 8, 2014
    California
    Hello friends, I was just wondering if there is a certain code that needs to be followed when it comes to running and having to mount pipe along the walls, i came across a situation where i had to replace a two inch ball valve that was in a very inconvenient spot so i took the chance to bring it forward to the front of the pipe chase where it is located and i had to mount it on the wall using steel hanger strap, i know in the back of my mind that the way its up there is incorrect but i work with a very very small budget and its all i had at the time and i need to know the proper way of mounting it so that it can pass code, thanks for any help :)
  2. Terry
    Aug 17, 2004
    The pipe can't touch concrete block, and you would need copper coated plumbers strap.
    They make a UPC tape that adhears to the pipe that prevents contact too.
  4. TheNewGuy
    Apr 8, 2014
    California
    ok thanks terry
Similar Threads: Code mounting
Plumbing Code Questions Existing Ejector pump layout basement bathroom- is it to code? New York-Suffolk county Oct 14, 2014
Plumbing Code Questions Vanity Remodel drain offset is this to code? Jun 5, 2014
Plumbing Code Questions Bathroom Plumbing Code Question Apr 24, 2014
Plumbing Code Questions I am a Canadian retired plumbing inspector there any American codes i can download ? Mar 24, 2014
Plumbing Code Questions Sewer Camera Code Requirements? Mar 8, 2014
