Code for Ethernet / AV wires
Discussion in 'Electrical Forum discussion & Blog' started by seaneys, Nov 30, 2008.
  1. seaneys
    seaneys New Member
    May 8, 2007
    Chicago Suburbs
    I'm going to put my ethernet and a/v cable in pvc conduit (extremely low voltage).
    What codes apply to network wiring. I do not see anything in the NEC.
    Thanks,
    Steve
  2. Speedy Petey
    Speedy Petey Licensed Electrical Contractor
    Jun 16, 2007
    NY State, USA
    NEC Chapter 8
  4. beekerc
    beekerc IT Consultant / Network Engineer
    Oct 9, 2008
    Seattle
    FWIW,
    I asked a licened electrician associate of mine the same question with regard to my basement, specifically, running rough-in wires through PVC (1-1/4" sched 40), and leaving an empty (same spec) pipe with pull strings for future expansions, proximity to A/C, HVAC and flourescent fixtures. I was told....
    - keep parallel runs of ethernet, telco and co-ax a minimum of 12" apart from A/C
    - keep cross-overs between lo-voltage and A/C as close to 90-degree, right angles, as possible
    - do not run A/C and lo-voltage through the same holds drilled through studs
    - that there were no restrictions regarding running through PVC
    no mention of code requirements/restriction was made, however since SP, above, has referenced an NEC chapter, it would be good to check out.
    B
  5. jwelectric
    jwelectric Electrical Contractor/Instructor
    Jun 14, 2007
    Instructor
    North Carolina
    ARTICLE 640 Audio Signal Processing, Amplification, and Reproduction Equipment
    640.23 Conduit or Tubing.
    (A) Number of Conductors. The number of conductors permitted in a single conduit or tubing shall not exceed the percentage fill specified in Table 1, Chapter 9.
    800.110 Raceways for Communications Wires and Cables.
    Where communications wires and cables are installed in a raceway, the raceway shall be either of a type permitted in Chapter 3 and installed in accordance with Chapter 3 or listed plenum communications raceway, listed riser communications raceway, or listed general-purpose communications raceway installed in accordance with 800.154 and installed in accordance with 362.24 through 362.56, where the requirements applicable to electrical nonmetallic tubing apply. The raceway fill tables of Chapter 3 and Chapter 9 shall not apply.
    830.110 Raceways for Low- and Medium-Power Network-Powered Broadband Communications Cables.
    Where low- and medium-power network-powered broadband communications cables are installed in a raceway, the raceway shall be of a type permitted in Chapter 3 and installed in accordance with Chapter 3.
    Exception: Conduit fill restrictions shall not apply to low-power network-powered broadband communications cables.
  6. beekerc
    Oct 9, 2008
    Seattle
    so for those of us who don't speak NEC Code on a daily bases, just to clarify, there is no restriction on network or a/v co-ax cables in a pvc pipe, short of what you can physically stuff inside it. correct?
    what about telco - is the 48 vDC of a POTS line considered "low voltage"? or would that fall under the "low power" exemption above?
    Sorry for being dense, just trying to make sure I get it right - I'd hate to have to de-pipe all the network runs i've done so far.
    Thanks
  7. jwelectric
    Jun 14, 2007
    Instructor
    North Carolina
    For the audio cable there would be a requirement but for the coax cable none.
    I would keep my audio and coax separate from each other so there wouldn’t be any high frequencies that bled from one to the other.
    Trivial yes but worth it in the end especially if this is a high end entertainment set up.
    My audio has a low hum but if I turn off the receiver it goes away. Sound and visual are in the same wire way.
  8. frenchelectrican
    frenchelectrican Electrician
    Jun 16, 2007
    Master Electrician
    NE Wis / Paris France { In France now }
    All my answer in Bleu colour.
    Merci,Marc
  9. beekerc
    Oct 9, 2008
    Seattle
    this makes excellent sense. however, on the office setups that i've done with cat5/5e/6 in the past, we usually pulled multiple wire bundles at once to get to to about 85% full, then pulled individual wires until pulling was difficult. we used wire pulling lube for the last half-dozen or so cables. in retrospect, it never occured to us that there might be an NEC code aspect to what we were doing, in part because the electricians we often worked with didn't regard us very highly since (in their words) "network voltage can't kill ya".
  10. seaneys
    seaneys New Member
    May 8, 2007
    Chicago Suburbs
    I'm struggling staying under the 360 degrees max bend requirement as I bob and weave around the EMT / metal conduit.
    I'm assuming the max bend radius rule applies for low voltage runs.
    Steve
  11. beekerc
    Oct 9, 2008
    Seattle
    bend radius for network/telco does apply but not as stringently as for solid copper wire. coax does have rules, but it's not so much a safety issue, but more of an issue with video signal performance. with network/telco, you just want to avoid sharp bends, but you can maneuver them through much tighter spots and corners than you would romex.
    i'm pretty sure there isn't anything in the NEC covering bend radius for low voltage/low power, but there are defnintely best practice guidelines.
Similar Threads: Code Ethernet
Electrical Forum discussion & Blog How does the Receptacle , the wiring, CB and code Relate? Mar 18, 2016
Electrical Forum discussion & Blog Electrical code questions. 2005 NEC Jun 15, 2015
Electrical Forum discussion & Blog Renovating Bathroom- Electrical Code Mar 11, 2015
Electrical Forum discussion & Blog Would this cable run down face of beam to wall (under beam)be up to code (Wisc)? Jun 5, 2014
Electrical Forum discussion & Blog Why am I certain this is against code? Apr 5, 2014
